Help! First time modification, concerned I screwed up
Solved by Deadly RexX,
Just now, bebejapes said:hi just to check all my boxs. could oyu boot it into bios mode and check if all the drives show up?
Hello, thank you for your response
- Also, I located the device in device manager after realizing another rookie mistake, figured out the device needed to be formatted (i guess?) and assigned a number. After running the wizard for this the drive is showing up properly in file explorer
