Fan not working
Solved by Senzelian,
It's not an issue. Your hardware will automatically clock down its frequencies to prevent damage and will cut power before damage can occur if necessary. But a single case fan usually doesn't have enough of an impact on the temperatures that this would occur.
However it's a good idea to monitor the PC temps anyway and I recommend to replace the fan as soon as possible.
