RX6800XT Core frequency issues at low GPU usage
Go to solution Solved by 191x7,
Try disabling the Ultra Low Power State (ULPS). And Multi-plane Overlay (MPO) from Windows.
Hello, Tech Tippers
To give some background, recently my RTX 3090 decided to crap out, no video out, not being detected in windows on multiple systems
During the meantime of RMA'ing it to EVGA, I've decided to drop in a RX 6800XT that I had laying around to hold me over, but lord I'm struggling
Right out of the gate feature wise I was aware I would be losing g-sync, and ray-tracing but come to also find out that I also lost the ability to have windows run 120hz refresh rate to my main monitor an Alienware AW3418DW(I'm guessing this is tied to g-sync)
However, the biggest issue is the severe downclocking the RX 6800XT is doing at low gpu usage where the core frequency would drop as low as 80hz!
These frequency drops has resulted in a choppy experience with anything that isn't putting load on the gpu. Which is driving me frankly nuts having 1080p youtube playback suddenly drop to 240p, choppy retro emulation, and desktop usage (it's choppy as I'm writing this post as well)
GPU temperatures are fine 52-75 degrees idle-load
As I became aware the frequency is closely tied to gpu usage as when I put actual load on the gpu it runs like a dream with stable advertised boost frequency
Using HWinfo to monitor the gpu core frequency, and I've set the min frequency in Adrenalin -100hz from max boost frequency, used MPT to disable the lower power states to ensure the gpu would stay in P1, also used DDU in safe mode removing the previous nivida drivers and AMD drives as I've initially suspected driver issues and did some clean reinstalls of Adrenalin and checking the GPU manufacture site and the vbios collection on techPowerup and couldn't find an newer vbios than whats on the GPU currently, re-enabled re-bar support as my mobo disabled it when I swapped out my 3090, and did multiple power drains on the system (removing system from power and holding the power button in for 5-10secs then plugging it back into power and then turning the system back on)
I guess, at this point I would like to know if this is what the average experience is for modern AMD graphics so that AMD can come out and say "Oh our new gpu's are more power efficient then nvidia b/c we aggressively throttle the gpu power at idle or low load" as I've been using nvidia as my main gpu vendor day 1 so was kind of looking forward to seeing what AMD was bringing to the table to compete with nvida. But it seems like to me that all the memes I've seen bashing AMD had some truth behind them
My system is as follows:
CPU: I9 10900X OC'ed to 5GHz
Memory: 32gb 4x8gb G.Skill Trident Z 3000MHz
Mobo: Asus Rampage VI APEX with latest bios
PSU: Corsair HX100i
GPU: Yeston RX 6800XT 16GB
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Using Radeon Chill in adrenalin software could help with this issue also, set a base fps which will be hit comfortably and set max to whatever you like.
Ive personally also seen good results by using enhanced sync in certain games (such as rdr2, i had the same problem you had in that game and for some reason this seemed to have solved that issue)
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
4 hours ago, deaththekid021 said:
Reporting back, using both suggestions, performance has certainty improved for low GPU usage applications, made sure to reset More Power Tools back to stock config(re-enabling c-states on the gpu)
apricate it
Just don't use Radeon Chill. Thats a feature that does more harm than good in most games/cases.
