I'm using a ASUS TUF A15 laptop, Windows 10 22H2. I didn't really use my touchpad much, always had a usb keyboard & mouse plugged in, since I'm bit of a rough user. Anyway I recently just realized that my right click button and the gesture controls aren't working anymore on the touchpad. I can left click and drag&drop but nothing else works. Even when I plug in my usb mouse I first have to right-click otherwise the usb mouse doesn't work either, the cursor moves but nothing else happens unless I right click on the mouse. As for the touchpad, I've tried driver updates, windows updates, touchpad settings, a regedit, physically enabling and disabling touchpad [ If re-enable the touchpad with the fn keys the touchpad only results with right clicks even with a single tap or left click ]. At times the mouse controls lock up randomly, unless I right-click on the USB mouse. I need some help. Windows says I have a precision touchpad. ( A rough guess what might've caused the problem could be that a few months ago, I was testing the xbox play cloud gaming service, I couldn't get my USB gamepad to work I installed a couple of drivers/softwares like HIDguardian and USB network joystick driver, I uninstalled those recently after figuring my touchpad wasn't working anymore so I thought uninstalling them might help ). Using the Dell MS116 USB mouse at the moment.
https://linustechtips.com/topic/1473241-touchpadmouse-issues-need-help/
