Should I use aio or air cooler
basically I have the elite 110 case from cooler-master and my plan was to put a Ryzen 5 5500 and a rtx 3060 in the case but am I fine with going stock cooler or will a 120mm aio make a huge difference to the temperature
(if I do need an aio which one should I go with my whole budget for the whole pc is 900 gbp)
https://linustechtips.com/topic/1473224-cooling-problem/
To answer your question, really there won't be much difference in final performance with an aftermarket cooler on either a 5500 or 5600.  They are not very hot chips, and the AMD stock cooler is still pretty good.  The gen 1 ryzens had a better cooler, but the current one is still pretty good.  The fan is made by cooler master.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1473224-cooling-problem/#findComment-15696310
