Power supply sparked
10 minutes ago, Pigmike312 said:This is my first pc build and I'm following a tutorial. I did a per startup with the power supply and the pc got to bios where it recognized my 4 pieces of ram and gpu. After that I placed the motherboard into the case connected everything up, other than the gpu. (I for got to hook up the power to it) when I went to turn on the pc, everything turned on and maybe a second or so later the power supply released a large spark and everything turned off. The whole event was silent.
The parts I used were a
AMD ryazen 7 5700G with radeon graphics
Asus Prime B45OM-A II
4 sticks of ram from silicon Valley
Radeon rx 580 gpu (when sparked happen it was unplugged)
The case was a nzxt h510 flow atx mid tower
And the power supply is from my old computer. It is a Apecia 900v non Modular
power supply. The pc was given to me by a friend and although the pc had many issues it never had power issues. I wanted to save money and so kept decided to keep the power supply. So when my cpu arrived I began building my pc, eventually leading the the spark.
I have no clue what happened, if anyone could let me know what happened and if this could have damaged any other parts, I would appreciate it, thank you.
PSU is dead at worst, and should be replaced at minimum. A $68 900W PSU is going to be DANGEROUSLY bad.
