Budget (including currency): $400, looking for GPU
Country: U.S.
Games, programs or workloads that it will be used for: FPS, other general gaming
Current Build :
Ryzen 7 3700x
GTX 1660 ti
Aorus b4450 Pro Wifi
500gb WD blue ssd
1TB HDD Segate Baracuda
Raidmax 600w gold power supply
https://linustechtips.com/topic/1472190-need-help-for-upgrade/
6700xt on ebay and a new PSU is gonna be your best bet. These cards haven't been out that long, and a lot of them have sat in boxes most of their lives.    Almost all raidmax PSUs are pretty bad sorry to say.
This would be your best bet:
GPU:
AMD Radeon RX 6700 XT 12GB GDDR6 Reference Graphics Card - Multiple Available 727419312905 | eBay
XFX Speedster Qick 319 Radeon RX 6700 XT 12GB GDDR6 Graphics Card Black 778656080980 | eBay
or new for $50 more with a smaller cooler:
ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card (RX6700XT CLD 12G) - PCPartPicker
PSU:
Deepcool DQ750-M-V2L 750 W 80+ Gold Certified Fully Modular ATX Power Supply (DP-GD-DQ750-M-V2L) - PCPartPicker
Enermax Revolution D.F. 650 W 80+ Gold Certified Fully Modular ATX Power Supply (ERF650AWT) - PCPartPicker
FSP Group Hydro GE 650 W 80+ Gold Certified Fully Modular ATX Power Supply (HGE650) - PCPartPicker
The rest of your system is great, though if you still have the stock cooler on your 3700x, abasic $20 aftermarket cooler will probably get you way better temps with less noise and better boost clocks:
Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler (AX120 SE-D3) - PCPartPicker
Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler (AX120 Refined SE ARGB) - PCPartPicker
or a big one to overclock the bejeesus out of itL
Thermalright Peerless Assassin 66.17 CFM CPU Cooler (Peerless Assassin 120) - PCPartPicker
Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler (PA120 SE White ARGB) - PCPartPicker
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1472190-need-help-for-upgrade/#findComment-15688872
