Help! Ram issues on a lenovo p50 laptop
Solved by Cyberat,
You're mix matching paired ram, but it is possible the laptop is not outputting enough voltage to run all 4 slots at once.
I'd stick to samsung memory and RMA the others, just cause it's an unknown brand of questionable quality.
Can you up the RAM voltage in Bios or is your Bios locked ? What are your voltage readings vs. specs. when 3 slots are full ?
What are the voltage specs. on the different RAM sticks ?
