Building a new system for a family member for Christmas.
Specs:
Ryzen 5 5600G (Purchased OTC from Memory Express)
Asus Dual RX6600 (Received today from Newegg via Purolator)
ASrock B550M Pro 4 (Ryzen 5000 ready stamped on the box, Received on Friday 12/03 from Newegg via Purolator)
16GB Corsair Vengeance LPX 3600mhz CMK16GX4M2D3600C18 (Purchased via Amazon)
SN750 500GB boot drive (Purchased via Amazon)
Cooler Master 650w PSU Gold+ Bronze
Performed pre-build test to ensure system posts before putting into a case, NO POST. All PSU plugs are seated Initial tests were with CPU, both sticks of memory in A2 and B2 and dedicated GPU all plugged in, LED boot debug indicates BOOT and VGA on. No POST, black screen. Fans spin on CPU cooler and on GPU.
1. Swapped DRAM to only one stick in furthest left slot - NO CHANGE
2. Removed GPU and installed Display-port cable directly to motherboard for use of iGPU, NO CHANGE
2. Googled, found someone saying no SSD or NVME was causing no POST, installed NVME, NO CHANGE
3. Referred to manual to clear CMOS, NO CHANGE
4. Moved GPU to secondary PCI slot, NO CHANGE
4. Swapped my personal R7 3800X into the CPU socket, NO CHANGE
5. Swapped my personal RX5700XT into the 1st PCI slot, NO CHANGE
5. Swapped my personal G.SKILL F4-3200C16D-16GTZRX (Trident Z 3200mhz 8GBx2) into slot A1, NO CHANGE
6. Installed the RX6600 to rule out DOA into my personal system, PASS WITH SUCCESSFUL POST.
7. Installed the R5 5600G onto my personal system to rule out DOA, PASS WITH SUCCESSFUL POST.
8. Installed the Corsair Vengeance LPX memory (1 stick at a time) into slot A1 on my personal system to rule out DOA, PASS WITH SUCCESSFUL POST.
9. Reinstalled and rebuilt all personal hardware back into my personal system, personal system POSTs with no problem. (I am using it now to create this thread.)
10. Installed all new hardware back onto new motherboard, NO POST. VGA and BOOT debug LED's illuminated.
Only thing I can rule out potentially is a bad Mobo. I am opening a ticket with Asrock, and posting here for provisional advise or tips.
Thank you.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1471762-vga-boot-led-no-post/
5 hours ago, Cyberat said:
Who told you 650W is good for a modern gaming system ?
You need 750W-850W if you want to be good.
But that's not even the point, I do confirm with all the 10 tests it's a DOA motherboard.
Not sure if trolling, 650w is plenty for this rig.
https://linustechtips.com/topic/1471762-vga-boot-led-no-post/#findComment-15686041
