First build help?
4 hours ago, UnendingOne said:@Pixelfie so I bought my NZXT H1 V2. Thinking I'll go 3060 since that seems to be the safe bet and I'm upgrading from a 1050ti anyways. Went with 500gb NVME SSD, because I can carry over my 2x256gb SSDs from my current computer for extra storage, and could always buy a bigger NVME drive later.
so I'm thinking these parts...
https://pcpartpicker.com/list/2cPk3y
Thoughts? Is there a reason I should go Intel i5 12400F and save some money on motherboard and processor, and also be able to upgrade to 13400F later?
What software do you use for video editing? AMD has apparently improved a lot for video editing in a lot of programs (but not every one), and their encoder has also improved a bit, so I think the 6700 XT will actually be better than the 3060 in most cases.
I still think 1TB is worth it over 500GB. It's only $25 more, and will save you an upgrade in the future.
12400F is better than the 5600 in every way. It's faster, supports newer upgrades, and the ITX boards for Intel are much cheaper currently, bringing down the total cost vs AMD. I recommend the 12400 non F instead though, because it has an iGPU which supports Quicksync, which can seriously improve render times for editing. The iGPU is also useful if you need to do some kind of troubleshooting.
Below is a list of what I'm thinking.
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor ($183.48 @ Amazon)
Motherboard: Gigabyte Z690I AORUS ULTRA LITE DDR4 (rev. 1.0) Mini ITX LGA1700 Motherboard ($140.98 @ Newegg)
Memory: TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($44.99 @ Amazon)
Storage: PNY XLR8 CS3030 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($74.99 @ Best Buy)
Video Card: ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card ($359.99 @ Newegg)
Custom: NZXT H1 - Small Form-Factor ITX Case - Dual Chamber Airfllow - Tinted Tempered Glass Front Panel - Integrated 650W 80+ Gold PSU, 140mm AIO Watercooler, and PCIe 3.0 High-Speed Riser Card - Bl ($200.00)
Total: $1004.43
Generated by PCPartPicker 2022-12-17 14:53 EST-0500
