[Planning] First PC build
Go to solution Solved by igormp,
6 minutes ago, AwakenedRedstone said:
My main priority is programming and Minecraft, sufferably some future proofing since I might need some 3D software later since I'm studying computer engineering.
ML is something I might work with sometimes, probably rarely.
I have considered a 3060, but fitting it on the budget might be tight.
Oh, you're doing college level stuff? Then you don't really need to blow that entire budget. A 5900x or 5800x3d from ali, 32gb of ram and a 1660 Super/Ti, 3050, 2060 or any similar Nvidia GPU should be more than enough for you.
You can take a look at GPU prices here: https://placasdevideo.app.br/
I'm not sure which kind of CompEng course you're doing, but I've done it and not even once I had to deal with 3D software.
Also, you're better off looking for recommendations in other Brazilian forums instead of this one.
Budget (including currency): BRL R$10,000.00
Country: Brazil
Games, programs or workloads that it will be used for: Minecraft Java Edition, Programming, Terraria, Starbound, (sometimes) 3D Rendering, (sometimes) AI/Machine learning training
I currently have a 7+ years old notebook with an i7-3612QM and 16GB of RAM, using it is getting harder every day, since I am getting into heavier loads while programming, and as Modded Minecraft gets heavier.
I do not plan to get any peripherals nor have any components to use on my new computer build.
I have a 1080p 60Hz monitor, I might get a second screen on the future, possibly 1440p, anything over that is overkill for me
I plan to get at least 24GB of RAM and 1TB of NVMe
I plan to build the system in the next month or two
https://linustechtips.com/topic/1470275-planning-first-pc-build/
Because PCPartPicker does not have a Brazilian version, i'll have to use craftmybox. Good thing Spanish is my first language.
Here's my link
https://meupc.net/build/vqc36v
  • Processador Intel Core i7 12700 2.1 GHz 12-Core
  • Placa de vídeo Sapphire Radeon RX 6800 16 GB Pulse
  • ASRock B660M-HDV Micro ATX LGA 1700
  • XPG Gammix D20 (Preto) 32 GB (2x16 GB) DDR4-3200
  • Crucial SSD P2 1 TB M.2-2280
  • Nox NXVIRTUS (Preto) MicroATX Mini Tower
  • Fonte Corsair CX750M 750 W Certificado 80+ Bronze Full-Modular ATX12V
  • There’s no feature to add 2 case fans, but please buy 2 if needed
Price :
R$ 9.331,81
Edited by PlayerLorenzo
Added specifications that fit your interests more
I edit my posts quite often, please refresh your browser if you can.
Specs :
OS : Windows 11 Pro
CPU : AMD Ryzen 5 4600G
RAM : 16GB 3200MHZ CL16 RAM
GPU : ASRock Challenger RX 6600
Display : Acer KA242Y
Mainboard : GIGABYTE B450M DS3H WIFI
Storage : 2TB Seagate Barracuda HDD
                240GB ADATA SU650NS38
54 minutes ago, PlayerLorenzo said:
PowerColor Radeon RX 6600 8 GB Fighter
They mentioned they are doing ML, so AMD is useless in this case.
Country: Brazil
What exactly are your priorities, and are you ok with used stuff? If so and your main priority is ML, you could buy a 3090 from OLX.
Otherwise, you could go for a 5950x and a more reasonable GPU. I don't think going for a DDR5 platform at your budget is worth it, but that's up to you.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
Lenovo N23 Yoga
I was unsure about that since I'm on the start of the course.
I'm here more to get mostly recommendations and an idea on what to go and look for, it is good to narrow down the options.,
Thanks for the recommendations, I'll give them a look
Then even your laptop should be more than enough for now. Once you start learning more stuff you'll actually know what you need.
Lenovo N23 Yoga
5 hours ago, AwakenedRedstone said:
The reason I'm getting a new computer is that the me current setup is struggling with some things, especially programming and modded Minecraft.
But what kind of programming exactly?
Lenovo N23 Yoga
Currently it is mostly Minecraft modding, but I plan getting into game development to.
Minecraft modding uses a lot of RAM, game development idk, it just crashes on my PC
Then a 5800x3d with 32gb of ram and an entry/mid level GPU ought to do it for you.
As for you college, unless you're in some private uni that wants to be trendy, you won't be needing/doing anything related to 3d games, nor games at all. Even most ML stuff at undergrad level should be doable with google colab.
Lenovo N23 Yoga
