In the past day or 2 my pc shuts off 10-15 minutes after booting up battletech. Ive had this issue before with Snowrunner but it just stopped doing it out of nowhere so I really dont know what fixed it. Ive moved my VGA cables to different ports on my PSU, ran in different window modes, put my power option to the recommended settings, even switched the plug my power cable goes into. My gpu drivers and windows are up to date.
CPU
Ryzen 7 5800x
Motherboard
Asrock B450m/ac
RAM
32gb Gskill Ripjaws DDR4 3200mhz
GPU
MSI RTX 3070 TI Gaming x Trio
Case
Phanteks p300a
Storage
1x Samsung 970 Evo Plus 2tb 1x ADATA Sata SSD 2tb
PSU
Super Flower Leadex III 850 80+ Gold
Display(s)
GIGABYTE g32qc-a 1440p 165hz
Cooling
Noctua NH-U12S w/ 2 NF-12S fans, 2x 140mm Noctua NF-A14 FLX Intake fans, 1x 120mm NF-A12x25 exhaust fan
https://linustechtips.com/topic/1470009-power-issue-with-pc/
Sorry if I missed it in the post but what are your temperatures of your CPU / GPU while gaming ?
Switching off is a sign of overheating or PSU failure.
CPU: Ryzen 5900x | GPU: RTX 3090 FE | MB: MSI X470 Gaming Pro Carbon | RAM: 32gb Ballistix | PSU: Corsair RM750 | Cooler: Sythe Fuma 2 | Case: Phanteks P600s | Storage: 2TB WD Black SN 750 & 1TB Sabrent Rocket | OS: Windows 11 Pro & Linux Mint
https://linustechtips.com/topic/1470009-power-issue-with-pc/#findComment-15672936
i also switched my PSU's fan mode from eco to performance and havent had a shutoff since, i really need a new case cause my current case chokes the PSU in a tight shroud
https://linustechtips.com/topic/1470009-power-issue-with-pc/#findComment-15672971
