Okay so I want to upgrade my PCs power supple because I need a new graphics card. My current build is...
Motherboard- Asus Prime a320m-k
CPU- Ryzen 5 2600
Ram- Corsair Vengeance 8gb x2( 16gb in total)
GPU-GTX 1060 3gb
PSU- Seasonic 500w
The power supply I got is a Cooler Master MasterWatt 650w and the GPU I got is an RTX 2060. For some reason whenever I put my new power supply in it won't turn on at all. I know it works because the motherboard has a yellow light that turns on when plugged in but it won't actually boot. The old power supply works fine though, I'm able to boot and load up everything with the old one. I'm really confused and I watched a few videos on it and they said to maybe reset the CMOS which I don't really know how to do and they to said boot with one ram stick which I also tried and it didn't work.
If anyone can help me that would be great!
https://linustechtips.com/topic/1469405-help-with-psu-upgrade/
Did you make sure you pulled all of the old PSU wires out and only use the cables that came with the new power supply?
Here is a link on how to clear CMOS. I recommend the reseating the battery method.
https://www.lifewire.com/how-to-clear-cmos-2624545
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1469405-help-with-psu-upgrade/#findComment-15668846
