need help building pc
Go to solution Solved by Dukesilver27-,
These prices are based on Tokped prices (Rp. x1000).
i3-12100F 1,577
MSI H610M-E PRO 1,385
PNY XLR8 2X8GB 3200MHZ 935
Powercolor RX6600 Fighter 3,634
MP33 512GB SSD 560
bequite! System Power 9 400w 700
AOC 24G2 2,850
Total 11641
This will perform much better than your list, some are low end parts, such as H610M board and PSU, but it should do just fine.
12100F outperforms 1600 by a mile, for not much more.
Cheap 2X8GB 3200MHZ RAM.
Good RX 6600 model.
Good value 512GB SSD, I personally have the 1TB version of it.
Higher quality PSU for a bit more, that seasonic model is on the lowest tier of PSU that is better to be avoided. FYR https://cultists.network/140/psu-tier-list/
The monitor is better than your pick, for not much more, FYR:
AOC 24G2 https://www.rtings.com/monitor/reviews/aoc/24g2
LG https://www.rtings.com/monitor/reviews/lg/24gl600f
Budget (including currency): $800 (Rp.12.545.201)
Country: Indonesia
Games, programs or workloads that it will be used for: AAA and Esports, some WFH with multi screen use
PART LIST :
AMD Ryzen 5 1600 ($82.90)
ASRock B450M-HDV ($63.77)
ASRock Radeon RX 6600 8GB ($230.53)
Seasonic S12III 650 ($60.77)
SX6000 Lite 256GB M.2 NVME ($25.70)
LG 24GL600F-B 144HZ ($159.42)
Is this good ? I've been waiting for 3 years to build a pc
https://linustechtips.com/topic/1469395-need-help-building-pc/
i3-12100F 1,577
MP33 512GB SSD 560
AOC 24G2 2,850
Total 11641
Good RX 6600 model.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1469395-need-help-building-pc/#findComment-15668799
i3-12100F 1,577
MP33 512GB SSD 560
AOC 24G2 2,850
Total 11641
Good RX 6600 model.
ah, can you recommend intel cpu for streaming ?
https://linustechtips.com/topic/1469395-need-help-building-pc/#findComment-15668897
