5.2ghz 1.38vcore, 1.1v vccio 1.12v vccsa avx offset 0. Llc turbo on a z390 aorus ultra. Vrvout underload is 1.31-1.32v. Temps are fine, passes cinebench 30mins, occt extreme large avx2 passes. When I set it to small extreme avx2 it crashes and cores spike to 104c not good. Planning on changing thermal paste to see if that makes a difference. Although id like to get it stable in occt small, but is it necessary? If anyone can shed some light or tell me the next steps to get it stable that would be great thanks.
https://linustechtips.com/topic/1467248-9700k-oc-help/
small extreme is a hell of a load to put on the cpu even not OC'd. sure my overclock isn't stable under that load, but if it works in all your applications that you use, then who cares? days of 24 hour prime95 stable are way past and quite frankly stupid. might not be exactly the answer you're looking for, but unless you need that application and that particular load, then it's kinda pointless going to that extreme
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652795
So you want it stable ons an extreme stress test?
How does it work normally? Stable in windows and gaming?
That's my definition of stable.  Stable under unreasonable loads isn't needed, it's useless.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652808
How many watts are you pulling at 1.38v pushing small ffts?  If it’s over 300w, you’re going to struggle cooling it. Also, what are you using to cool it.
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652809
180w… under load it’s 1.31v bc of my llc. 240mm aio. Crashes in p95 smallest
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652835
Seems stable in gaming so I guess it’s fine… thought it crashed once in cinebench r20, never in r23. Scored 10100 in r23. I guess that’s good?
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652837
It seems that it peaked at 97c when it crashed on r20, I just maxed my pump and all my fans, cpu didnt get over 90c and it passed r20. Seems the higher the temp the more voltage it needs.
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652864
Yes it’s called power leakage.
are u pushing ur cpu just for fun and benchmarks ? Because realistically I won’t notice a difference between 5.2 and 5 ghz for gaming with the fps counter turned off
may as well run it cooler at lower voltage
like my cpu will do 5.6p and 4.4e but there’s just no need for it
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652938
You can use HW Monitor to see the actual wattage you’re pulling.
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652946
Mostly for fun lol… my 5ghz is stable for occt small avx2. Draws 210w like that and no errors. High llc, 1.32v in bios and 1.2v underload… can’t seem to get 5.2 stable in occt… I’m thinking with a better cooler I could push more voltage
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15652958
U need more llc if ur dropping from 1.32 to 1.2 under load
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15653347
Im on LLC high, I could go turbo and reduce vcore but I read somewhere that the medium settings are the best on the z390 aorus ultra. I think a buildzoid video? Am I wrong?
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15653772
I don’t no I’m not an expert I just always set llc so it doesn’t drop under load then turned the vcore down
Maby someone else can tell us does llc push all voltages up or only vcore
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1467248-9700k-oc-help/#findComment-15653849
