I have a $600-$700 USD budget  this is what I am looking at for the build
Motherboard: MSI Z87-G45
Cpu:  i5 4670k
Cpu Cooler: Cooler Master Seidon 240M or Noctua NH-D14
Ram G.skill Spiner 8gb 2x4gb
Case: Corsair Obsidian 450D
I have 840 Evo 120GB ssd, 1 TB WD black, and a gtx 670, and 750 watts psu
I would like the know if the parts above are good
https://linustechtips.com/topic/146718-looking-for-upgrade-help/
Cpu:  i5 4670k
What do you have now?
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/146718-looking-for-upgrade-help/#findComment-1959266
that nearly the same build i am going for, ecpet the case is going to be a Fractual Design R4, GPU is going to be the gtx 770 and the cpu cooler is the Noctua NH-U14s. The build you are going to do is going to be good for gaming, you could probably get about 50-60fps in high demanding games like BF4 on high settings.
        My PC Specs:          CPU: i5 4690k(stock speed of 3.50GHz)          GPU: MSI GTX 770 4GB          Storage: WD Blue 1TB HDD and 120GB Samsung 840 EVO SSD             Ram: 8GB Corsair Vengeance Pro 1600MHz           Motherboard: Z97 Asus Maximus VII Ranger          PSU: Corsair RM650 650W          CPU Cooler: Coolermaster Hyper 212 EVO                    Case: Fractal Design R4 Black Pearl with window         OS: Windows 10 Pro
https://linustechtips.com/topic/146718-looking-for-upgrade-help/#findComment-1959390
What's the system being used for? Are you planning to sli?
https://linustechtips.com/topic/146718-looking-for-upgrade-help/#findComment-1968869
