So I upgraded my pc to ryzen 7 7700x with 16gb ddr5 ram, and from the start I had problems installing windows from usb, I removed a stick of ram and it installed, after installation I put the other one in and it worked for a bit then pc starting crashing. BSOD's like memory_management error and some others like somekind pool error in file system or whatever it is. And many many more which I googled and it indicated that it could be a driver, software or ram error
There was a problem also while it lasted for example my discord kept refreshing, sometimes pc doesnt even boot or post until multiple tries.
i want to make sure if it could be ram issue so I dont RMA the wrong one
P. S now it doesnt work even with 1stick of ram, cant even get to bios. If I try another slot than a2 or b2 motherboard gives dram error code
P.S.S the problem is having full power etc. Fans spinning etc. And monitor kinda turning on to no picture or boot etc.
https://linustechtips.com/topic/1466496-problem-with-new-updated-pc/
Update: resetted bios so docp gets disabled, got into windows and so far its fine, even opened a game without a problem
Edit: restarted to try to get into bios and it does the same thing with green light being up (motherboard manual says its "BOO")
