Need upgrade advice
Go to solution Solved by NF-A12x25,
15 minutes ago, Faris14 said:
Budget (including currency): 400 EUR(For cpu and mb)
Country: Austria
Games, programs or workloads that it will be used for: cyberpunk 2077, R6, CSGO, Valorant, sim racers and other AAA games, programing and some video editing
Other details : Current parts:
Intel i3-10100f; Gigabyte b460m d3h; 2x8GB 3000Mhz cl16; Saphire rx 6600; Corsair RM 750x; 32" 1440p 165Hz Monitor
So above mention are my current parts, I want to game at 1440p as much as possible and will be upgrading to either a 6700xt or new rdna3 gpu when they come out. I am thinking of upgrading my cpu and mobo first and in january or february upgrading the gpu so that is one thing to take into consideration but I will upgrade it 100% to one of the mentioned.
I need some help in choosing what processor to buy considering that I will mostly use it for programing and gaming, some editing for a friends yt channel as well. Currently I am debating between a 5600x and 12400f because they fit my budget the best. If you guys have any other suggestions I am open for them I do not mind buying used as well.
Thank you everyone in advance!
I would get an i3-12100f and a B660M Bazooka motherboard from MSI, then when locked 13th gen processors release (they are going to be a better value than the 12400 due to having e-cores on the locked i5’s) you can upgrade to one of those and sell the 12100f. https://at.pcpartpicker.com/list/kYMH3y
The mobo I chose is a really good one, especially for the price. I have done some builds with it. It has enough power delivery to handle even a 13th gen i9 boosting to its max frequency. The most recent build was an SFF build in a Meshroom S for my gf, which is an ITX case that can actually fit an ATX or mATX motherboard.
Country: Austria
https://linustechtips.com/topic/1466392-need-upgrade-advice/
Country: Austria
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646085
2 minutes ago, NF-A12x25 said:
I would get an i3-12100f and a B660M Bazooka motherboard from MSI, then when locked 13th gen processors release (they are going to be a better value than the 12400 due to having e-cores on the locked i5’s) you can upgrade to one of those and sell the 12100f. https://pcpartpicker.com/list/kYMH3y
Did not know that the 13th and 12th gen use the same socket that is a pretty good option. Thank you very much will look into both items from the list.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646096
yup with intel they do 2 generations per socket except for the first gen. It’s 1, then 2-3 4-5 6-7 8-9 10-11 12-13 and 14 will use a different socket.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646119
Nice to know, one more question what do you think about the ASUS TUF B660m plus instead of the msi board
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646121
decent board but not as good as the MSI board- the MSI board has better VRMs. 10+1 on the Asus board vs 12+1+1 on the MSI board. That means the CPU will get better power on the MSI board.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646130
Ohh okey then I will get that board and that cpu should I upgrade my ram as well or wait when i get 13th gen to upgrade ram then? And thank you very much you have been very helpfull with all of this.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646139
your ram is good enough. If you have been running into issues where you have used up too much of your ram you can get a matching kit if you want, your ram is on the slow side for DDR4 but not too slow.
If you upgrade I would get a 32gb kit of 3600mt/s DDR4 and sell your old kit on ebay, but it’s not a priority.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646146
Depending if I am hosting a server for certain games like zomboid or minecraft I have ran into that issue so I will look into a nice kit after I upgrade the cpu first, will go for the specs you have mentioned.
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646150
https://pcpartpicker.com/product/7MVmP6/oloy-blade-rgb-32-gb-2-x-16-gb-ddr4-3600-cl18-memory-nd4u1636181drkde
Here’s a good kit of 3600 cl18
https://linustechtips.com/topic/1466392-need-upgrade-advice/#findComment-15646175
