I have recently reset my boot driver due to having issues with my storage being full, after resetting my PC keeps crashing 10 or so minutes after booting with error code resource not found.
if it helps I used didn’t use a media drive when resetting windows and used cloud download
windows 10
https://linustechtips.com/topic/1466391-resource_not_owned-stop-code/
Format the drive properly and reinstall Windows using the installer not the cloud download.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Update:
I followed an arguably vague Microsoft solution (while waiting for reply) by doing a startup disk check and it seems to be working(?), should I still try that on the safe side or wait for an error to pop out?
I ran chkdsk to see if I have an bad sectors on my drive, it seems I’m on the safe side according to it
2 minutes ago, Roseberry said:
Update:
Scratch that, I’ll try your solution got an error Right after posting
