I have a network card but i have no idea where to find the drivers for my card and install it without an internet connection. I have tried programs but they need and internet connection. If anyone can help i have a RealTek Semiconductor RTL8168/8111 PCI-E Ethernet NIC if i could get the driver for it i will be able to install it.
https://linustechtips.com/topic/146470-network-drivers-help/
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
Just download the right one and put it on a USBStick
https://linustechtips.com/topic/146470-network-drivers-help/#findComment-1956015
when did you delete the driver? if it is pretty recent, you should be able to recover using a system restore point.
Windows 7 I downloaded it but now it is a matter of installation. I deleted the network card from my device list becasue of was unidentifed. What do i do to intall this now?
Use the quote or multiquote, for faster responses \/ \/
https://linustechtips.com/topic/146470-network-drivers-help/#findComment-1956107
