okay let me start off by saying, i have had this pc for around 8 months...  just 2 months ago i started to get disconnected from my wifi. when i check my phone the wifi is still there. i always have to troubleshoot my Wi-Fi to get reconnected. i dont know what to do at this point. i feel like i tried everything. i even bought a new pcie WIFI card. ive tried deleting and reinstalling the wifi drivers still nothing. im at the verge of just destroying my custom built pc. PLZ HELPPPCapture.thumb.JPG.fbb89354fce4a1a90832118df8b1124c.JPG
Are you really getting disconnected from Wi-Fi (like a signal issue) or is your pc losing a valid Ip address randomly? Failing that maybe BEETLEGUISE BEETLEGUISE BEETLEGUISE!
and try reserving an ip for your computer with the router. Best of all would be to use an ethernet cord with this presumably expensive custom computer.
7950x-Aerolus x670 Elite Ax 64gb ddr5 5800 OC crap ram 2x 980 pro 2tb Zotac Tinity OC etc 3080 ti LG Ultragear 48gq900 138hz Gaming oled
tbh i dont even know, like i can be playing some or even watch youtube and it just turns off. i dont know how to describe it but all i know is that my pc loses the internet but my other devices such as my phone keeps the wifi on. im 50% sure its not a signal issue because i do run 220+ mbps up and down. i dont really have access to ethernet, haha yea no my pc is pretty average for what i paid for
Ok if your wifi card is like mine it may be one you can actually find another driver for to test. If you post exactly what it says it is in device manager we might be able to find an alternate driver for you to try and see if it is more stable.
Like I said though I would also reserve your ip in the router if you can do that.
what do you specically need to see, just a general picture or a picture with the driver?
how can i reserve a ip?
I can't help you, you need to look up on youtube how to do the ip reservation thing for your router.
You are also going to have to look up "How to go to device manager to see devices" and do that for the network card.
is this it?
Yes that is it. You have options now the easiest is the old remove and reboot. It should reinstall upon entering windows. The other thing you can do is go to https://www.intel.ca/content/www/ca/en/products/sku/204836/intel-wifi-6e-ax210-gig/downloads.html and grab the latest and greatest driver again to try
You'll need to look up your router it is all fairly similar but not enough that I can guide you without knowing the router.
These are the things I would try to troubleshoot and have in the past.
