Some help choosing Fans =[
'Kay, here's the situation. Got a new giga z87 mb which has 4 pin fan connectors, my old fan's have 3. Upon a quick google search it would seem my fans not having that last slot would just set em to default max speed and i won't be able to control it (correct me if im wrong here). I'd much rather have control.
Now should i just upgrade my fans (going to be getting a phantom 820 + x60 kraken for cooling in future so i'd like them with that case in mind). if so, which? Fan noise isnt much of a problem as i generally faze out all unneeded sound's while playing dota2, bf4, youtube etc and i do intend to OC  my rig (3670k and future 770 or above / 800 series single card).
or
Should i just go for the quick fix and get a cable that take's my current old stock Antec fans (came with the antex 300 case) 3pin that connect's to a 4pin so i can keep fan speed control...if such a thing exists?
Regards
Preston
 Motherboard  ROG Strix B350-F Gaming | CPU Ryzen 5 1600 | GPU Sapphire Radeon RX 480 Nitro+ OC  | RAM Corsair Vengeance DDR4 3000MHz 2x8Gb | OS Drive  Crucial MX300 525Gb M.2 | WiFi Card  ASUS PCE-AC68 | Case Switch 810 Gunmetal Grey SE | Storage WD 1.5tb, SanDisk Ultra 3D 500Gb, Samsung 840 EVO 120Gb | NAS Solution Synology 413j 8TB (6TB with 2TB redundancy using Synology Hybrid RAID) | Keyboard SteelSeries APEX | Mouse Razer Naga MMO Edition Green | Fan Controller Sentry LXE | Screens Sony 43" TV | Sound Logitech 5.1 X530
https://linustechtips.com/topic/146347-some-help-choosing-fans/
or
Regards
Preston
I'm sure the phantom comes with a built on fan controller, just use that and control them manually, however if you really want PWM control you are gonna have to replace the fans, a 3 pin to PWM adapter doesn't exist. But I think replacing them
Is a waste of money if you don't mind noise, use the phantoms fan controller.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/146347-some-help-choosing-fans/#findComment-1954833
Ty for replying, but i don't think you fully understand what i'm asking lol  :P
I'm not looking for a fan controller. I'm looking for a 3->4pin adapter so my fan speed wont sit @ 100% 24/7 (which is what ive read if you just connect a 3pin into a 4pin) If there isnt a 3->4 adapter option then new fan's are in order. So i'm also asking which fans toget for healthy air flow if it come's to getting new fans.
regards.
https://linustechtips.com/topic/146347-some-help-choosing-fans/#findComment-1958457
regards.
There's no such thing as a 3 pin to PWM adapter.
That's why I reccomend a fan controller so you don't have to have your current fans at 100% all the time and don't need to but new fans. But if you really want new fans, get anything from Noiseblocker or Noctua, just make sure they are PWM.
https://linustechtips.com/topic/146347-some-help-choosing-fans/#findComment-1958694
