First time building pc
47 minutes ago, ArunSH said:the ATX 4-pin power connector but i don't know what it means.
It's just that the board has an extra 4 pin that's only really used for serious oc
47 minutes ago, ArunSH said:Have no plans on overclocking.
Then id probably switch out the board primarily then since that board is really only bought for oc
47 minutes ago, ArunSH said:Is this pc kinda overkill for my needs?
At least the gpu, yeah. That's more of a 1440p ready gpu and the resolution id expect from this budget
47 minutes ago, ArunSH said:Is the air cooler too big for my case?
It's not to big for the case, but it's overkill for your cpu. Something like the deepcool ak400 is a better choice
47 minutes ago, ArunSH said:Is AIO better than air cooler?
Only usually 360 and up is where you'll see some benefits. But it's not needed for the cpu you've put in. I'd reccommend looking at the newest gen i.e 13600k which might require a bit more cooling
47 minutes ago, ArunSH said:Is it compatible with lga 1700 socket?
By now all coolers should come with the needed bracket
47 minutes ago, ArunSH said:Is ddr5 ram and compatible motherboard worth it or is ddr4 fine?
Ddr5 isn't worth it, at least for your uses, unless you go with the newest gen ryzen which requires it
I won't answer the rest of your questions, I'll just make a new list and describe My reasons
https://no.pcpartpicker.com/list/6rt6xs
The 13600kf is one of the best cpus on the market right now and with it being only 100 nok over the 12700, it's a pretty obvious choice
Good cooler that can handle the 13600kf easily
The board availability in Norway appears to be a bit odd, so the h670 tomahawk is the cheapest board I could find with bios flash
16gb of ram which should be enough for gaming
A bit cheaper 1tb storage
Cheaper 3070ti since the 6800xt was a bit more expensive
Nice case with airflow for your parts and a good 750 watt psu that can handle all of them
