Budget (including currency): $US 2000
Country: United States
Games, programs or workloads that it will be used for: FPS games, streaming, recording, video editing
I need help finding a good rgb case and rgb cpu cooler. I'm also concerned about the stock fans that come with the case and the rpm's they run at to keep my pc cool. I had 2 sets in mind, the corsair icue 4000x and icue H115i Elite or the Fractal Design Meshify 2 RGB paired with the Fractal Design Lumen S28 RGB. If those 2 aren't good what would you recommend.
https://pcpartpicker.com/list/Pjd8mr
https://linustechtips.com/topic/1463145-build-help/
The Meshify 2 RGB & Lumen S28 RGB can use the motherboard's A-RGB lighting control. Meshify 2 RGB fan speeds can be controlled through motherboard utilities.
Corsair uses its own environment and I don't think the memory lighting can be sync'd with iCUE.
https://linustechtips.com/topic/1463145-build-help/#findComment-15621917
but the fans in the Meshify 2 RGB and on the Lumen S28 only run at 1200rpm's and thats quite low isnt it?
https://linustechtips.com/topic/1463145-build-help/#findComment-15621929
The case and AIO fans are 140mm with variable speed between 500rpm and 1700rpm. Airflow up to 78cfm, more than enough for decent airflow.
For a quiet system one ideally wants fans to run only as fast as needed to achieve acceptable cooling.
https://linustechtips.com/topic/1463145-build-help/#findComment-15621937
Im trying to achieve good cooling however in all my builds i have never really kept an eye on temp and have been fine. i currently have a 280mm front mounted aio and 2 140mm fans on top/back
https://linustechtips.com/topic/1463145-build-help/#findComment-15621965
Either of the combinations outlined in the OP should be fine. The Meshify 2 has much better Airflow than the 4000X.
https://linustechtips.com/topic/1463145-build-help/#findComment-15622490
Good to know and thank you. I did more research last night and found that out, especially the stock fans in the Meshify 2 compact run faster than the stock fans in the 4000x and I get +1 fan in the Meshify 2. However, the AIO cooler I wanted isn't being sold at the moment because there was a problem with the soldering within the pump causing high temps over time affecting the coolant mixture within the pump. According to Fractal their new fix/design should be out in the second week of November, just in time for Black Friday.
https://linustechtips.com/topic/1463145-build-help/#findComment-15622794
