PC stutter issue when moving mouse
Go to solution Solved by harrytwhite04,
After asking on Reddit someone suggested the possibility of a memory leak
I left my pc on overnight and came back to the stuttering, but closing SignalRGB stopped the stuttering immediately.
I'm not sure if it was a memory leak because task manager said it was only taking up 300mb of ram but it seemed to fix the issue 🙂
If it's USB (especially on a wireless dongle), try swapping USB ports. It does make a difference sometimes.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
