First Timer! Cooling Configuration
1 hour ago, Denosaur22 said:Phantex Eclipse P600s
This looks like a versatile case in that you can remove the front solid panel when you need more airflow. I suggest you keep this option open as a solid front panel will suffocate your components, especially in the Summer & even with just the side slits used as intake.
The included 3 x 140mm fans may do the job…But since you got your own fans…
1 hour ago, Denosaur22 said:Phantex PH-F120T30 120MM Fan (x7)
[Setup A]…You shouldn’t need all of them, so at minimum, I’d start with 3 front intakes & 2 exhausts (1 rear & 1 top-rear)…
Check your temps/noise. I think this should be enough, but if you want to make use of the two other fans…
[Setup B]…Add 1 intake to the top-front…check temps/noise…
[Setup C]…Add 1 exhaust to the top-middle…check temps/noise…
Compare A, B & C & decide which is the best overall config you prefer.
If you need help with fan curves, let us know as that’ll assist with the noise in each config above, which may let you get away with having more fans in the case.
Edit…
Setup A is for an open front panel (Mesh, not solid).
Setup B & C are more for a closed front panel because the extra intake on the top with help the fronts which are behind that solid front panel & hence unable to suck cool air in as efficiently.
This is why I highly recommend you remove the solid front panel, as that’s the main intake of cool air, not only in quantity but also efficiency because the air is pointed directly at your warmest components & allowed to flow across your board & then exit in the rear/top-rear corners naturally.
If you block off that front entrance, then it throws your airflow way out.
