Building my first ever pc and well it’s not going well. I have no video outputs from gpu or motherboard. It’s not the cables, my motherboard light turns orange, then red, then white, and also idk where this supposed 4 pin connector is
Rog B550 F gaming motherboard and speedster swft 6600 xt
https://linustechtips.com/topic/1462109-need-help-with-a-build/
Those cables on the last picture with the round connectors are molex you don’t need them. The thinner ones are SATA cables for 2.5/3.5” SSDs and HDDs
For a start route the 4+4 pin CPU connector over the top of the MB not through the bottom as you’re blocking off the entire GPU slot.
Where is your GPU? What CPU is it?
Generally an additional 4 pin is to provide more power to CPUs that need it for when you OC them.
https://linustechtips.com/topic/1462109-need-help-with-a-build/#findComment-15614328
Its ryzen 5 5600x 4th Gen and a Speedster swft210 amd Radeon rx 6600 8 cores
https://linustechtips.com/topic/1462109-need-help-with-a-build/#findComment-15615297
Have you actually put the card in yet? You won’t get a display out from your MB as that CPU doesn’t have an iGPU.
Just plug in the GPU into the slot and plug a PCIE power connector into it
https://linustechtips.com/topic/1462109-need-help-with-a-build/#findComment-15615327
Ok new issue im my motherboard boot device light turns on now
https://linustechtips.com/topic/1462109-need-help-with-a-build/#findComment-15615504
