So I'm currently looking around at cases and am looking for Inverted Left Side Panel Cases with a window, I.E. Silverstone Raven series, any recommendations?
My Must haves for the case is mounting of some sort for 3x 2.5in drives and 3x 3.5in drives and 240mm radiator support.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/1461128-inverted-left-side-panel-window-cases/
If it’s a matx board you can use a thermaltake core v21.  Theyre modular so you can set them up how ever you want.  They even stack.
Edited by Bombastinator
I'm currently ATX, would looking at maybe building another system next year for an ITX pc for work.
|King Of The Lost|
Thermaltake has an even smaller cheaper case that is basically the same for itx boards. It’s on the large side of SFF, but that just means there is tons of space in it.  There’s a bigger one as well that fits atx.  I don’t know what it is called though.  That would start to reach truly ungainly proportions. They’re all shaped more or less like a third of a stick of butter.   It’s an older design so it’s cheap.  Even has external hose access.  Decent design though.  At least the matx one.  They sell em at microcenter.  They’re REAL cheap there.  The atx one would have truly crazy amounts of space.  Like “yeah I’ve got sixteen hard drives, so?” Kinda space.
