current specs:
msi h410m pro vh
intel i3 10100F
8gb ram(4*2)
Gt 710
I am going to upgrade my gpu to an rx6600 right now.
in the future i will upgrade my cpu to ryzen 5 5600x.(obviously the mother board and maybe ram too)
I know that the ryzen 5 and rx6600 goes well I've seen that configuration a lot.
But what i want to know is will the rx6600 paired with the i3 cause any problems?
https://linustechtips.com/topic/1460412-will-this-configuration-cause-problems/
No problems, only bottlenecks, which you will fix later slightly,
a question though, how about your PSU is it powerful enough to power the new GPU you're planning to buy?
current PC:
PC configs I used before:
No, i don't think so. What wattage psu would be ideal for my configuration
What PSU do you have? AMD recommends 500W PSU for RX6600
current PC:
