3 minutes ago, crazyamerican12 said:
So i recently ordered a msi rx 6800 xt gaming z trio and it requires 3x 8 pin PCI-E my psu only has 2 8 pin pci e is there any way to safely solve this problem without buying a new psu
The 6800XT don't really need 3 connections it's 300ish W, it'll work with only 2 (each 150W + 75W from the board), my 3080 only has 2 and needs more power
https://linustechtips.com/topic/1458465-gpu-pci-e-problem/#findComment-15588230
If you don't have the needed connectors then it simply wont work.
What psu do you have?
https://linustechtips.com/topic/1458465-gpu-pci-e-problem/#findComment-15588276
It'll work with one double connector using only 1 PSU slot, plus the second one
https://linustechtips.com/topic/1458465-gpu-pci-e-problem/#findComment-15588282
1 hour ago, jaslion said:
The 650m has 2x 6+2 x2 cables so you can plug it in. If it only has one you can buy an official extra
so, pigtails or splitters whatever there called don't really matter in this case sense it is getting plenty of power from 2x8 pins, correct?
https://linustechtips.com/topic/1458465-gpu-pci-e-problem/#findComment-15589411
