Hey LTT,
I have a 780 ti classified that won't go stable with anything +50 mhz or above on both memory or core. What is a safe voltage offset to add? I'm using Evga voltage boost and i have it set to max +12 mV. Is that safe?
Thanks!
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/145773-what-is-a-safe-voltage-offset/
On air, you will be fine 24/7 at 1.25v if you ever decide to push it further with a 3rd party BIOS and the Classified tool. Just be sure your temps are ok.
