Choosing a Power Supply...
Go to solution Solved by jmaster299,
What about the OCZ Fata1ty 550w?
Or the Ccoler Master Gx II 550w ?
Get the Corsair RM550 like someone else already recommended. It is Corsair current gold line of PSU and even got approval from Linus for nearly silent operation. Newegg even has Linus's video embedded at the bottom of their sales page for it. 550w is more than enough headroom for overclocking your CPU. There is no need to overclock your GPU as it will do that on it's own. If your temps are good your boost clock will exceed the advertised boost clock for the card. Your PSU is not something you cheap out on.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139053
I was confident to go with the OCZ ZT 550w Power Supply, with my h87 mobo and Asus gtx 760.
But here on the forums, i was able to cut costs and opt for an Asus gtx 770 and was convinced into overclocking
I read that the minimum wattage is 600w for the 770
So will the OCZ ZT 650w just do it?
Or should I go For something like 750w ?
Rig:
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.98 @ OutletPC)
Motherboard:  Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard  ($158.98 @ OutletPC)
Memory:  Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($84.99 @ Newegg)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($80.99 @ Amazon)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.98 @ OutletPC)
Video Card:  Asus GeForce GTX 770 2GB DirectCU II  Video Card  ($328.99 @ SuperBiiz)
Total: $1051.21
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-28 09:01 EDT-0400)
PSU not included as it is under discussion....
https://linustechtips.com/topic/145430-choosing-a-power-supply/
550W would be enough, just if I remember correctly those OCZ ones are loud and annoying.
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941807
I think you need a Diablotek
VBR6mKu.pngLOL wtf.
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941833
LOL wtf.
its a reference to a techquickie video about psus
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941878
No I'm wtfing that their site has blacklisted my entire country  :lol:
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941882
Your estimated wattage is 428W. A 550W will be more than enough. Even a 500W would be fine. Id also recommend getting a PSU from brands like Seasonic, Corsair, XFX, Cooler Master, even EVGA makes some good PSU's.
That is the estimated minimum wattage. Since he has plans on overclocking, I would at the least go for a 550w. If it was me and I was going to be overclocking my Graphics card and my CPU, then I'd opt for 600. More room for upgrades, room to overclock, and more peace at mind.
//ccap
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941927
your rig is likely same like me, and i using Corsair RM550, and i do OC on my CPU and GPU and use liquid cooling
go on gold efficiency 550-600W will be enough if you only use for 1 video card and overclocking IMO
CPU i5 4670k @4.5GHz | Motherboard MSI Z87M Gaming | RAM 2x4GB Patriot Viper 3 | GPU MSI GTX 760 Hawk | CPU Cooler CM Nepton 140XL | PSU Corsair RM550 | Case BitFenix Prodigy M
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1941964
i7 2600K @ 4.7GHz/ASUS P8Z68-V Pro/Corsair Vengeance LP 2x4GB @ 1600MHz/EVGA GTX 670 FTW SIG 2/Cooler Master HAF-X
http://www.speedtest.net/my-result/3591491194
https://linustechtips.com/topic/145430-choosing-a-power-supply/#findComment-1946082
