Hi all,
I need a laptop for uni and am torn between a few options. I would need around 16Gb ram and a touchdisplay with a 360 degree hinge/pen input. In terms of size I was mostly looking at 14" & 13" because I'm pretty sure I broke my back with the last one I had.
My budget is around 1500 € or so, important is more that the laptop lasts long enough. No big gaming or anything, just coding and drawing/sculpting. Any OS is fine (even no OS at all).
The options I found were:
  • Lenovo ThinkPad L13 Yoga G3 (Intel OR AMD)
  • Lenovo Yoga 7 (Ryzen)
  • ASUS ZenBook Flip 14 OLED
Link to Austrian price comparison site with all of the models in different options selected
Looking forward to your input on which of these models/configurations is best, particular the ancient question of... Intel or AMD?
In case of the OLED screen I am a little bit worried about brightness and overall I've heard rumors that Thinkpads are the most durable ones.
Also any recommandations on different models that fit my requirements are more than welcome.
Thank you in Advance
https://linustechtips.com/topic/1452918-help-me-make-a-choice/
