Hello, Samsung S32BM700 monitor does not have any audio out ports. It has bluetooth, however, reduced audio quality and delay is unacceptable.
Current setup is as such: monitor has a usb-c hub built-in, so I connect my laptop to monitor using 10GB usb-c cable, which then charges laptop and sends 4K60hz video to the monitor. At the back of the monitor there are usb-a ports into which I connect wireless mouse and keyboard, which are recognized by the laptop.
So my question is - if I connect 3.5mm to usb-a DAC into monitor usb-a port and speakers into DAC, will my laptop see audio device and I will be able to play music through it?
https://linustechtips.com/topic/1452071-audio-out-using-usb-c/
Yes, as its just another USB device on the hub.
https://linustechtips.com/topic/1452071-audio-out-using-usb-c/#findComment-15542614
