CoolerMaster Universal GPU Vertical Mount Compatibility
Go to solution Solved by Dukesilver27-,
It's fine, you'd just need to change the PCIE speed to gen 3 in BIOS.
I use that vertical mount with an RX 6800 XT, no performance difference.
1 thing to note tho, If you have a big or massive air cooler, make sure you have the clearance.
Because that mount positions the GPU slightly higher than it needs to be.
Budget (including currency):
Country: Philippines
Games, programs or workloads that it will be used for:
Does the CoolerMaster Universal GPU mount will work on RTX 3060 w/ PCIE 4.0 even if the riser only supports PCIE 3.0?
Occassionaly visits the forum when I have nothing to do at work.
