Hey!
For some reason, my computer has a habit of suddenly freezing (deadlock) while gaming. When it freezes, I just force shut down the computer (by holding the power button) and manually turning it on again then running "sfc /scannow" and "dism /online /cleanup-image /restorehealth" in Powershell that is ran as an administrator. Running the SFC command seemed fine however, when running the DISM command, I noticed that it goes from 0% to 50% then suddenly jumps to 100% saying that the restore operation completed successfully. Is this normal? I have even done a clean installation of windows in my machine but the percentage still jumps.
I have looked at its logs (CBS.log) and this is what the summary says:
022-08-23 17:22:16, Info                  CBS    Appl:Feature On Demand package without explicit comparator, using GE on build version
2022-08-23 17:22:16, Info                  CBS    Appl:Feature On Demand package without explicit comparator, using GE on build version
2022-08-23 17:22:19, Info                  CBS    Package Format: PSFX
2022-08-23 17:22:19, Info                  CBS    Appl:LCU package and revision compare set to explicit
2022-08-23 17:22:19, Info                  CBS    Repr: Staged package check completes
2022-08-23 17:22:19, Info                  CBS    Exec:Only CSI metadata corruption found, Process CSI repair.
2022-08-23 17:22:19, Info                  CBS    FLOW: Entering stage: RepairCsi
2022-08-23 17:22:20, Info                  CSI    00000009 Creating NT transaction (seq 1)
2022-08-23 17:22:20, Info                  CSI    0000000a Created NT transaction (seq 1) result 0x00000000, handle @0x12328
2022-08-23 17:22:20, Info                  CSI    0000000b Transaction UoW: {b76d982c-22b8-11ed-89b6-9c5c8e886673} for BeginTransaction
2022-08-23 17:22:20, Info                  CSI    0000000c@2022/8/23:09:22:20.111 Beginning NT transaction commit...
2022-08-23 17:22:20, Info                  CSI    0000000d Transaction UoW: {b76d982c-22b8-11ed-89b6-9c5c8e886673} for CommitTransaction
2022-08-23 17:22:20, Info                  CSI    0000000e@2022/8/23:09:22:20.271 CSI perf trace:
CSIPERF:TXCOMMIT;160144
2022-08-23 17:22:20, Info                  CSI    0000000f StoreCorruptionRepair transaction completed.
2022-08-23 17:22:20, Info                  CBS    Repr: Finished repairing CSI store.
2022-08-23 17:22:20, Info                  CBS    FLOW: Entering stage: RemoveStagedPackages
2022-08-23 17:22:20, Info                  CBS    =================================
2022-08-23 17:22:20, Info                  CBS    Checking System Update Readiness.
2022-08-23 17:22:20, Info                  CBS    Summary:
2022-08-23 17:22:20, Info                  CBS    Operation: Detect and Repair
2022-08-23 17:22:20, Info                  CBS    Operation result: 0x0
2022-08-23 17:22:20, Info                  CBS    Last Successful Step: Remove staged packages completes.
2022-08-23 17:22:20, Info                  CBS    Total Detected Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CBS Manifest Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CBS Metadata Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CSI Manifest Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CSI Metadata Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CSI Payload Corruption:    0
2022-08-23 17:22:20, Info                  CBS    Total Repaired Corruption:    0
2022-08-23 17:22:20, Info                  CBS        CBS Manifest Repaired:    0
2022-08-23 17:22:20, Info                  CBS        CSI Manifest Repaired:    0
2022-08-23 17:22:20, Info                  CBS        CSI Payload Repaired:    0
2022-08-23 17:22:20, Info                  CBS        CSI Store Metadata refreshed:    True
2022-08-23 17:22:20, Info                  CBS    Staged Packages:
2022-08-23 17:22:20, Info                  CBS        CBS Staged packages:    0
2022-08-23 17:22:20, Info                  CBS        CBS Staged packages removed:    0
2022-08-23 17:22:20, Info                  CBS    Total Operation Time: 1236 seconds.
2022-08-23 17:22:20, Info                  CBS    Ensure CBS corruption flag is clear
2022-08-23 17:22:20, Info                  CBS    Ensure WCP corruption flag is clear
2022-08-23 17:22:20, Info                  CBS    All CSI corruption was fixed, ensure CorruptionDetectedDuringAcr is clear
2022-08-23 17:22:20, Info                  CBS    Failed to clear CorruptionDetectedDuringAcr store corrupt flag (slow mode trigger). [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2022-08-23 17:22:20, Info                  CBS    CheckSur: hrStatus: 0x0 [S_OK], download results: <none>
2022-08-23 17:22:20, Info                  CBS    Count of times corruption detected: 0
2022-08-23 17:22:20, Info                  CBS    Seconds between initial corruption detections: -1
2022-08-23 17:22:20, Info                  CBS    Seconds between corruption and repair: -1
2022-08-23 17:22:20, Info                  CBS    Reboot mark cleared
2022-08-23 17:22:20, Info                  CBS    Winlogon: Simplifying Winlogon CreateSession notifications
2022-08-23 17:22:20, Info                  CBS    Winlogon: Deregistering for CreateSession notifications
2022-08-23 17:22:20, Info                  CBS    Exec: Processing complete, session(Corruption Repairing): 30979790_4155204696 [HRESULT = 0x00000000 - S_OK]
2022-08-23 17:22:20, Info                  CBS    Session: 30979790_4155204696 finalized. Reboot required: no [HRESULT = 0x00000000 - S_OK]
2022-08-23 17:22:20, Info                  CBS    Deleting directory: \\?\C:\Windows\CbsTemp\30979790_4155204696\
2022-08-23 17:22:20, Info                  CBS    Moving directory from \\?\C:\Windows\CbsTemp\30979790_4155204696\ to \\?\C:\Windows\CbsTemp\30979790_4155204696\{48B3CC4A-4FD8-490D-BB81-16511F3032FA}
2022-08-23 17:22:20, Info                  CBS    Failed to move \\?\C:\Windows\CbsTemp\30979790_4155204696\ to temp directory \\?\C:\Windows\CbsTemp\30979790_4155204696\{48B3CC4A-4FD8-490D-BB81-16511F3032FA} [HRESULT = 0x80070020 - ERROR_SHARING_VIOLATION]
2022-08-23 17:22:20, Info                  CBS    Failed moving directory: \\?\C:\Windows\CbsTemp\30979790_4155204696\ to temp, will delete in-place instead [HRESULT = 0x80070020 - ERROR_SHARING_VIOLATION]
2022-08-23 17:22:20, Info                  CBS    Deletion of: \\?\C:\Windows\CbsTemp\30979790_4155204696\ successful
2022-08-23 17:22:20, Info                  CBS    Session: 30979793_3637159422 initialized by client DISM Package Manager Provider, external staging directory: (null), external registry directory: (null)
It clearly says that the operation was Detect and repair however, the last successful step was "Remove staged packages". Also looking at the summary, Seconds between initial corruption detections and Seconds between corruption and repair is -1 and I believe this isn't normal.
I have searched the web for answers but it doesn't seem that there is a solution that is the same as my problem. I hope that anyone could give some advices on what to do. Cheers!
NOTE: and yes, all my of drivers are updated and I have tried other troubleshooting methods to solve my deadlock problem but it doesn't seem to work for me.
Edited by Jownjown
Forgot to attach image
|| i5 6400 || Asus H110M-D || 8GB Crucial Ballistix || MSI GTX 1060 Twin Frozr || 1 TB Seagate || Cooler Master Blizzard T2 Mini || Seasonic M12II 520W 80+ Bronze || Deepcool Dukase ||
https://linustechtips.com/topic/1451045-dism-help/
Not related to your question, but try to wiggle your RAM stick while the pc is running. If that make your pc locked up, you might need to clean the RAM contact and RAM slot.
https://linustechtips.com/topic/1451045-dism-help/#findComment-15535228
Holy crap, it did lock up.
Is it better to use an eraser or a q-tip with a bit of alcohol to clean the ram modules?
Also, I don't really have access to a air compressed can. Is it safe to just use a brush (I use a big paint brush to brush off dust lol) to brush the RAM sockets?
https://linustechtips.com/topic/1451045-dism-help/#findComment-15535253
Yeah, I usually use eraser or a paper to clean the contact and camera lens blower to clean the slot or sometime brush, just make sure there is no dust inside the RAM slot before you put back the RAM.
https://linustechtips.com/topic/1451045-dism-help/#findComment-15535261
Will definately do this tomorrow, thank you. So the next time I wiggle my RAM, it shouldn't deadlock correct?
https://linustechtips.com/topic/1451045-dism-help/#findComment-15535289
