Every time task manager started, it will use a lot of CPU to check all the programs/services that are open.
So it is possible that your CPU can't handle that much processing at the same time.
What is your CPU?
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1450968-taskmanager-issues/#findComment-15534687
