Depends on the phone, the camera and the software. Normally an indicator should be on when the camera is in use, and off otherwise. Sometimes an indicator briefly lights up when the device is starting up and the software doesn't know yet if the camera is in use or not. Other times it might be a diagnostic indication that the camera tried to power on but failed. A bit like a beep code but with light.
https://linustechtips.com/topic/1450392-camera-indicator/#findComment-15531109
