Budget (including currency): 1200
Country: Spain
Games, programs or workloads that it will be used for: 1080p and 1440p gaming and future 4K
Hi, I need help deciding parts for my itx build. I am using currently ryzen 1600 build, and I can reuse the ram and the gpu.
Going intel requires ddr5 (which is really expensive and I already have a decent kit). Wait for 7000 series maybe too long when a good value itx am5 board comes out.
I will keep my 2060super until 40 series comes out. It works well in 1080p.
I know the cooler is overpriced but I am really into the looks of it, I think it is worth the price for me.
Here is the parts list:
PCPartPicker Part List: https://es.pcpartpicker.com/list/6jk7Mb
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  (€204.79 @ Neobyte)
CPU Cooler: NZXT Kraken Z53 RGB 52.44 CFM Liquid CPU Cooler  (€248.95 @ Coolmod)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard  (€193.64 @ LIFE Informatica)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€77.97 @ FNAC)
Storage: Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive  (€159.37 @ Amazon Espana)
Video Card: NVIDIA GeForce RTX 2060 SUPER 8 GB Founders Edition Video Card
Case: Lian Li Q58 (PCIe 4.0) Mini ITX Desktop Case  (€144.95 @ Coolmod)
Power Supply: Corsair SF750 750 W 80+ Platinum Certified Fully Modular SFX Power Supply  (€164.95 @ Coolmod)
Total: €1194.62
Thanks in advance
https://linustechtips.com/topic/1450159-sff-pc-part-selection-help/
tbh i really disagree with your cooler choice, you could get more ram AND a bigger ssd if you switched to a different one but whatever floats your boat
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Going intel dosen't require ddr5, you can use ddr4, but if you wish to upgrade in the future, you will need to change mobos as well.
And honestly go for a smaller samsung drive and use it as a bootdrive, and use the extra money to get a secondary, like a 2tb seagate drive, and put your files and games on there
Not necessarily. Plenty of DDR4 mobos. I added some new ram in my recommendations cause it's faster but you said your current ram is fine so keeping it would be no issue (guessing the white Corsair ram is what you have?)
Here's an AMD option
PCPartPicker Part List: https://es.pcpartpicker.com/list/zsNDnt
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (€177.94 @ Coolmod)
CPU Cooler: ARCTIC Liquid Freezer II 120 56.3 CFM Liquid CPU Cooler (€72.43 @ Amazon Espana)
Memory: Klevv BOLT X 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (€68.00 @ Amazon Espana)
Storage: Crucial P2 1 TB M.2-2280 NVME Solid State Drive (€88.99 @ FNAC)
Video Card: NVIDIA GeForce RTX 2060 SUPER 8 GB Founders Edition Video Card (Purchased For €0.00)
Case: Silverstone SG13 Mini ITX Tower Case (€57.72 @ Amazon Espana)
Power Supply: NZXT C750 750 W 80+ Bronze Certified Semi-modular ATX Power Supply (€53.80 @ Neobyte)
Total: €712.52
Generated by PCPartPicker 2022-08-18 17:08 CEST+0200
Cheaper SSD cause €160 for 1TB is criminal. This case also accommodates ATX PSUs which are cheaper, so that's nice.
Intel option:
PCPartPicker Part List: https://es.pcpartpicker.com/list/Zyz9nt
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor (€204.79 @ Neobyte)
Motherboard: ASRock B660M-ITX/ac Mini ITX LGA1700 Motherboard (€160.21 @ LIFE Informatica)
Total: €705.94
Generated by PCPartPicker 2022-08-18 17:10 CEST+0200
Primary PC:
PSU tier list
How many watts do I need?
Yeah, I know it is pretty expensive. It is just for the looks...
But currently ddr4 itx mobos are extremely expensive and the cheaper ones (Asrock ones really sucks).
The boot drive suggestion I really think would be great.
Total: €712.52
Intel option:
Total: €705.94
The problem with intel is that Asrock boards are bad viewing the reviews. And there is no choice of other ones in Spain currently.
Do you have a local shop that might offer more alternatives? Or can possibly order an in-store selection for you?
ASRock customer support is bad sure, but a lot of their products are pretty good. Though it seems specific information about this motherboard is hard to come by, I'll have to dig around for its VRM setup info.
Primary PC:
PSU tier list
That's a good idea. I can ask one.
If it’s the RGB you want, the Arctic Liquid Freezer II A-RGB is a much, much better cooler for a significantly cheaper price. The Lian Li Galahad 360 is also much better.
You could build a system like this that will perform well and remain a looked, something similar to this:
CPU Cooler: Cooler Master MasterLiquid ML240 Illusion 47.2 CFM Liquid CPU Cooler  (€119.78 @ Amazon Espana)
Motherboard: Biostar B660GTN Mini ITX LGA1700 Motherboard  (€191.80 @ Alternate)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€87.66 @ LIFE Informatica)
Storage: Crucial P2 2 TB M.2-2280 NVME Solid State Drive  (€156.99 @ Amazon Espana)
Case: SSUPD Meshlicious (PCIe 4.0) Mini ITX Tower Case  (€180.94 @ Coolmod)
Power Supply: Cooler Master V750 SFX GOLD 750 W 80+ Gold Certified Fully Modular SFX Power Supply  (€149.99 @ Amazon Espana)
Total: €1091.95
Generated by PCPartPicker 2022-08-19 12:09 CEST+0200
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
