85 Celsius is quite normal for these workstation cards when they're a standalone unit.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1448544-gpu-cooling/#findComment-15517645
I would still recommend replacing thermal paste and clean out dust, its technically fine but its pretty warm. I couldnt find the maximum temperature online.
https://linustechtips.com/topic/1448544-gpu-cooling/#findComment-15517663
I was mistaking the model for a much newer card so the thermal paste is probably a lot older than initially thought
Primary PC:
PSU tier list
https://linustechtips.com/topic/1448544-gpu-cooling/#findComment-15517675
