Recently I bought an adapter from USB-C to DVI-I (Dual Link) since my laptop has only USB-C hub to connect displays. I am using BenQ XL2411 Monitor, but the thing is that it supports 1080p, 144hz only via DVI-D Dual Link. I have a cable DVI-D (Dual Link) on both ends and it connects perfectly into the adapter and monitor, but whenever I try to set the hertz up above 60 it says: "Incorrect cable. Please use the DVI dual-link cable, that came with your monitor."
I do understand what is says, but unfortunately I don't have the original cable anymore, but I wonder, is there something special in their cables or I just can buy another cable and it will work? But why mine doesn't, if it's DVI-D Dual Link on both ends and that's exactly what my monitor asks for.
Notice: it supports up to 120hz, screen is showing the picture, but once in a while it goes black for a second, but the "error tab" in bottom right just makes me sick, it's not disappeaing.
Using this image to say which cable I need/have.
Edited by greN1337
https://linustechtips.com/topic/1445917-incorrect-cable/
My brother used to have one of these monitors, before he switched to a part of 1440p 144Hz DELL monitors.
No special cable, you MUST need DVI-D to get 144Hz.
Your USB-C adapter, with DVI-I is a problem.
You need an adapter that supports DVI-D, 1080p 144Hz.
There are a bunch of USB-C to DVI-D adapters, BUT if you check the specs, they are limited to 60Hz only.
Some info to read:
https://forums.tomshardware.com/threads/how-to-connect-to-a-120-hz-display.3268285/
THIS was one of the recommended USB-C to Dual Like DVI-D adapters....it's $100.
https://www.amazon.ca/dp/B07QKM856C?tag=georiot-ca-default-20&ascsubtag=tomshardware-ca-9996018073539970000-20&geniuslink=true
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1445917-incorrect-cable/#findComment-15498930
