question regarding WIFI router placement
AnimeDudeJ
My parents just got fiber and they want to move their WiFi router to another spot (the model is a TP-link archer C3200)
the house is roughly 10x10 meters and the walls are around  6cm or 2.5 inches thick with am old chimney in the center of the building, I've been trying to figure out where to mount it and I'm unsure if it's a good idea to wall mount it on the second floor on one end of the house.
what would the difference be between mounting it horizontal on the wall, or om the slanted ceiling or even on the ceiling?
i could also mount it on the wall on the floor directly bellow, but that would make routing the Ethernet cable trickier.
thanks in advance for any input as I am not very experienced in working with wireless networking stuff as all my devices use cables where possible.
You're overthinking.  Try for the center of the home, as wifi is a bubble.  Note that certain build aspects of a home (excess piping in a wall, or other metal features in a home) can impede the signal. Hit or miss though.
My home and router had no issue with bathroom piping and a metal tub, but my buddy has a staircase that must be made of lead since no signal can penetrate it.
You'll find your dead zones over time, it's just trial and error at that point then. For now, just place it where you don't have to look at the ugly thing.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
@Dedayog is pretty spot on. Aim for the middle and see what happens. As long as the house isn't made of pure stone and lead, you should get pretty good speeds throughout.
My apartment is about 1000 square feet (slightly smaller than 10x10m) and my ISP provided router doesn't have any issues. But, at the same time, my GF's house is a fair bit older and her router can't reach from the front, room to the bedrooms at the back. She didn't want me to spend too much time optimizing things and running cables, so her ISP just gave her an additional mesh tower and called it a day.
I just tried wall-mounting it pretty much dead centre next to the chimney and I was honestly a bit shocked at how good the reception in the kitchen was.
the kitchen is about a few meters diagonal through the chimney on the first floor. I am considering trying a spot on the 1st floor though and seeing if reception is acceptable on all floors though.
aaand I was just informed I could not mount it by the chimney as it leaks... looking for other suitable spots as I type this.
