Sidetone for microphone
16 minutes ago, Bakerrr said:Understood, what are your opinions on discord noise suppression.
Also input sensitivity is that just something I should mess with or put it on automatic
Tbh, none of their stuff is necessary while using a headset mic. Since the mic is right up front your mouth in that case, you can't easily mess things up. All Discord's methods of suppressing, adjusting etc ends up doing nothing much else than messing up your experience. You can test this for yourself - turn off the settings one by one, do a test up above that settings page to hear your own self. Turn them on and do again... it's like Discord by default puts a noise gate to your mic that is overly aggressive set up. Just cuts a significant portion of your gain / volume.
I've tested this with various high end mics, none of those settings actually helped.
As for the input sensitivity, it's a setting you can adjust if you want. It's the amount of noise in decibels that Discord starts to record your volume. When it drops down below a certain threshold, your voice is no longer heard. It's set to auto by default, though I'd suggest using push to talk if you could. That way, you make sure your voice always goes to the other client without skips due to sensitivity settings. You're also eliminating other unwanted noises to get to the other side by using push to talk. I just set push to talk on my mouse side button so things get easier that way.
