Would be nice if you guys could rate it
Sorry for my dirty glass panel 😕
Ryzen 5 1500x oc @ 3,9ghz
Nvidia Geforce GTX 970 (withoud the shroud)
Alpenföhn GPU Cooler with 2 Arctic 120mm fans
Msi b450 a pro max
2x8 gb G skill aegis oc @ 3200mhz
500 Thermaltake RGB Psu
White cable extensions
Corsair H100x Aio
500gb Sandisk ssd
Sharkoon pure steel rgb case
https://linustechtips.com/topic/1443877-my-updated-build/
17 minutes ago, bmx6454 said:
it's definitely getting long in the tooth, but it looks nice. how much drive storage is available on that case? really digging the case.
What do you mean by getting long in the tooth?
And its a pretty big case I could easily fit a 3080 in here.
https://linustechtips.com/topic/1443877-my-updated-build/#findComment-15484889
i meant like hdd's. and i don't mean anything bad by the phrase, just that the pc is getting older, but if it does the job, who cares.
https://linustechtips.com/topic/1443877-my-updated-build/#findComment-15484934
I miss the white CPU cooler, but big fans and big heatsinks on GPUs are my weakness, so I love it! 😄
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/1443877-my-updated-build/#findComment-15485478
