Meshify 2 cooling differences.
Go to solution Solved by fonzz1e,
minimal diff until u start putting drives after front fans, even then temp diff is only a few degrees
Anyone who has had experience building a PC in the Fractal Meshify 2, do you know what the difference is between how airflow works in its default layout, or the converted layout (where you have additional spaces for 3.5" and 2.5" drive bays?
I only plan to install one 3.5" HDD in my future build, but quite like the additional space it would give for cable management and being able to remove the drive cage at the bottom. But will it have any detrimental affect on airflow and cooling?
CPU: Ryzen 7 1700  |  Motherboard: Asus Strix X370-F  |  RAM: Corsair Vengance LPX 32GB
Case: Phanteks Enthoo Luxe White  |  Cooler: Cryorig R1 Universal
Storage: Samsung 970 Evo SSD M.2  -- Samsung 850 Evo 500GB SSD SATA  --  2x WD Caviar Green 2TB HDD  -- Seagate 4TB HDD SATA -- Seagate 3TB HDD SATA
Display: Dell U2713HM -- Viewsonic - VX2257  |  PSU: Corsair RMi Series RM850i
My Current PC: https://uk.pcpartpicker.com/list/dvmmLs
https://linustechtips.com/topic/1443281-meshify-2-cooling-differences/
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
I am thinking of removing the drive cage, and have my one 8TB HDD low down.  But I am thinking more for the aesthetic.  If I like the cables being hidden, I wouldn't want it to affect the cooling.
FYI storage mode will be slightly harder to blow out the dust
When I clean the PC, I tend to go with a portable air blower, so that should dislodge things.
