RTX 3080 not being properly utilized.
Solved by xg32,
check power, temps and core usage during load, make sure the fans are on and it's not overheating (some cards are default off), if you haven't ddu'd try that.
Timungus1 ·
3
kerriya ·
Posted in Graphics Cards4 -
woodlandgamer ·
Posted in New Builds and Planning3 -
2
jordanbuilds1 ·
Posted in Graphics Cards2 -
2
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
