cables Quick question
Solved by JoeCooper,
5 minutes ago, GuiltySpark_ said:Will this work? Its a very old style, you're not likely to find too many USB3 specifically rated versions like this.
https://www.amazon.com/Belkin-Pro-USB-Extension-Cable/dp/B0002Y6CYM/
Yes sir and i just found this one as well, Amazon.com: BUSlink 2.5ft USB 2.0 A Male to A Female Extension Extender Cable (76CM) : Electronics
