What is the Best Capture Card that has AT LEAST 4k 120hz passthrough with the ability to Capture between 1080p - 1440p 60hz?
I want to capture my Main Computer (MacBook Pro) Screen and use my Secondary Computer (Windows PC) to be able to take those visuals and Stream it to Twitch via OBS.
https://linustechtips.com/topic/1439858-best-capture-card/
AFAIK that simply doesn't exist yet, you'll have to do it in software.
F@H
GPD Win 2
https://linustechtips.com/topic/1439858-best-capture-card/#findComment-15457168
