Hi,
I still have the stock cooler as my CPU cooler. Its been almost a year still I brought my PC.
I had no cooling issues, except from time to time the cooler RPM gradually increases and then decreases.
On my PC there's only one fan which is a exhaust, I wanted to get a cooler but I'm not sure whether to get a CPU cooler or cooling fans.
My Build:
  • CPU - Intel i5-10400F
  • Motherboard - Asus ROG Strix B460-H gaming motherboard
  • RAM - Corsair Vengeance Pro RGB 16GB (8*2) 3200Mhz
  • GPU - MSI Ventus XS GTX1650 4GB DDR6
  • Case - Corsair 110R
  • Storage - Lexar NM100 250GB SSD, WD 1TB HDD
  • PSU - Corsair CV450 80+ Bronze
  • Display - Samsung 24-inch
  • Keyboard and Mouse - Logitech MK220 Wireless Combo
https://linustechtips.com/topic/1439857-stock-cooler/
If your not having any issues than why are you thinking about buying a new cooler? Have you run a stress test to see what the temps are?
Due to my inability to think before I type, I frequently edit my posts. Please refresh before responding!
Tag me @drdrewnatic or quote me so I can see your response.
______________________________________________________________________________________________________________
CPU: INTEL CORE I5-12600K GPU: ASUS ROG STRIX GEFORCE RTX 2070 OC MB: GIGABYTE B660 AORUS MASTER DDR4 RAM: 2X8GB G.SKILL TRIDENT Z RGB 3200 CL16 BOOT: CRUCIAL P5 PLUS 1TB SSD: SAMSUNG 860 EVO 500GB HDD: SEAGATE 2TB 7200RPM PSU: EVGA G3 650W COOLER: THERMALRIGHT PEERLESS ASSASSIN 120 SE ARGO
01101100 01110100 01110100 01110011 01110100 01101111 01110010 01100101 00101110 01100011 01101111 01101101
https://linustechtips.com/topic/1439857-stock-cooler/#findComment-15456940
Just now, Nalina Artigala said:
I've run some tests before, any recommended apps for that?
Cinebench shows you the more real world example for what you'd expect doing intense stuff but if you want to see how far your cooler can go then there's nothing better than Prime95.
HWiNFO64 for monitoring temps.
https://linustechtips.com/topic/1439857-stock-cooler/#findComment-15456945
12 minutes ago, Nalina Artigala said:
Hi,
My Build:
Fans ramping up and down is normal. Dust out your PC if you're noticing it fan up more often. Otherwise, a decent inexpensive air cooler with a big fan like the legendary Cooler Master 212 Evo will make for a virtually silent CPU cooler.
Prime95. There are probably better and more advanced ones, but this still works a treat.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1439857-stock-cooler/#findComment-15456946
I've run the multi-core test and the pts is lower than before it dropped from 7110 to 5761
https://linustechtips.com/topic/1439857-stock-cooler/#findComment-15456986
Ok, and the temps?
Like another person said, when was the last time you cleaned out your PC? If you buy some compressed air and blow out all the dust, that could make a difference.
https://linustechtips.com/topic/1439857-stock-cooler/#findComment-15457075
