will it work?
Solved by Jorgemeister,
Yes it would, but you still need RAM and a drive
Use PCPartPicker, they let you pick compatible parts, here is your list so far: https://pcpartpicker.com/list/C6tDzf
Also, You are using a CPU with integrated graphics, but you will have a GPU so you dont really need them, it works fine though, and you would have a backup if you were touse your PC without the GPU, not sure if that is your intention.
